1. buzzersdad's Avatar
    When dialing, receiving calls, and while talking, android goes into an endless loop asking for "double tap to unlock". Hugely annoying, and I can't find any settings that will get rid of this. At other times, the phone works OK. Using android 4.4.2 on a (old) Samsung DUOS.
    07-24-2019 07:56 PM
  2. mustang7757's Avatar
    Been awhile since I used a phone with KitKat , can you post screenshot?
    07-24-2019 09:49 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! That screen typically shows up for phones that lack a proximity sensor, or phones that allow you to turn off the proximity sensor. The reason for the double-tap is to prevent your face from accidentally pressing onscreen buttons while you have the phone up to your face during a call. Do you know if your phone has a proximity sensor? If it doesn't, I don't think you can turn that feature off. If it does have a proximity sensor, then open the Phone app and look through its settings for an option to turn the screen off during a call.
    07-24-2019 11:10 PM
  4. mustang7757's Avatar
    Yeah , I think your right, remember something like that back then .
    07-25-2019 12:21 AM
  5. buzzersdad's Avatar
    Here is screenshot:
    how can I get rid of the "double tap to unlock" message that keeps appearing when using telephone?-screenshot_2019-07-25-14-45-29.png
    07-25-2019 02:56 PM
  6. mustang7757's Avatar
    Here is screenshot:
    That looks likes app locker, do have something like that install?
    07-25-2019 02:58 PM
  7. buzzersdad's Avatar
    Not that I am aware of. I've never installed one.... is there any way such a thing could be included in the software that came with the phone? How would I know? How would I find it?
    07-25-2019 03:33 PM
  8. B. Diddy's Avatar
    Did you happen to read my post no. 3 above?
    07-25-2019 03:59 PM
  1. Why wont my battery charge why im using my phone
    Last Post: 07-26-2019, 08:51 PM
  2. Phone chart of button functions
  3. I cant unlock my phone
    Last Post: 07-25-2019, 10:43 PM
  4. Voice recorder stops recording when screen goes dark on Samsung s8
    Last Post: 07-25-2019, 02:06 PM
  5. How do I find the clip tray on Lg stylus 4
    Last Post: 07-25-2019, 12:08 AM
