    I thought they went into PHOTOS at one point. It isn't happening now. I am on 8.1
    07-27-2019 12:13 PM
  2. mustang7757's Avatar
    Hi, if you can register a account here, me or other members be happy to assist you .
    I'll provide a link to register so you can communicate here.
    https://forums.androidcentral.com/as...community.html
    07-27-2019 12:43 PM
  3. Morty2264's Avatar
    Welcome to Android Central! What kind of phone are you using? Usually, screenshots are stored in Photos --> Screenshots folder. My Pixel 2 has everything sorted on the same page, but some phones may have side menus, maybe to the left hand side.
    See if the issue persists in Safe Mode or after you restart your device. Maybe it's a glitch of some kind.
    07-27-2019 01:54 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! I believe @Morty2264 is referring to where you find the Screenshots folder in the Google Photos app. The actual directory (if you're using a file manager app) is /Pictures/Screenshots.
    Morty2264 likes this.
    07-27-2019 11:57 PM
  5. TennKirk's Avatar
    Screenshots used to go into PHOTOS, but no longer. I am using. Moto G4+. I checked that the screenshot editor is off already. I am on 8.1 OS.
    07-29-2019 09:13 AM
  6. Javier P's Avatar
    Welcome to the forums. Try this, open Google photos, open the side menu (hamburger icon top left or swipe right from the left edge), tap 'Device folders' and then select 'Screenshots'.
    07-29-2019 09:18 AM
  7. B. Diddy's Avatar
    Duplicate threads merged. Review the other responses if you haven't already.
    07-29-2019 08:44 PM
  1. Where did the clock and other widgets go?
    Last Post: 07-28-2019, 12:11 AM
  2. Are they listening in?
    Last Post: 07-27-2019, 11:52 PM
  3. Possible malware attempting to screenshot my phone?
    Last Post: 07-27-2019, 11:46 PM
  4. Where does the charger get plugged in on the series 4 smart watch
    By Android Central Question in forum Apple Watch
    Last Post: 07-27-2019, 04:21 PM
