09-11-2019 06:18 PM
28 12
tools
  1. LettoLetto's Avatar
    Looking currently for 2 phones, 1 for me & 1 for my sister, looking to spend the $130-150 budget to get both, just had a look today & here's what I found so far:
    LG X Power for $50 "Great working condition just has a crack in the screen other wise works perfect", I replyed & asked "any pictures showing the crack? Are you open to offers?" I got the reply "The crack is on the side to the bottom whats your offer" "Otherwise whats your offer its like brand new has case and everything" I replied with "If it's still usable & the crack don't interrupt the touch or visibility when watching videos I'm thinking maybe $40?" got the following reply's back "Everything is clear works perfect" "When would you like to come""And 40$ is fine""Im using it now", if I were to get it it would be for my sister: https://www.kijiji.ca/v-view-details...dId=1457943039
    LG G4 for $80 obo, "purchased in 2016 & used for 1.5 years, spent all that time in a otterbox case that's included, also included is a 32GB micro SD card, at about the 1.5 year mark it experienced the bootloop issue, sent it in to get repaired & at that time purchased a new phone, came back from warranty repair with a new motherboard and the issue was resolved, also has a very new battery that was purchased a couple months before the bootloop event, battery will last all day with moderate use", would be for me: https://www.kijiji.ca/v-cell-phone/g...obo/1457771042
    LG G4 seller also got a Samsung Galaxy S3 for $50 obo "was purchased back in 2013. Used for 2 years, and it still works well. The battery will last the whole day with moderate use(texting and phone calls). It has 16gb of internal storage, and you can insert a micro sd card and a sim card in where the removable battery is located" would be for my sister, so would be $130 for both at the asking price: https://www.kijiji.ca/v-view-details...dId=1457767046
    Motorola Moto G5 (XT1670) listed for $80, would be for my sister: https://www.kijiji.ca/v-cell-phone/k...ale/1457720555
    Samsung Galaxy A5 2017 for $75, "The phone is in great shape but the battery indicator always seems to read 58%; whether I've charged it for hours or have been using it for hours, it never seems to go up or down (i.e. I think the battery fully charges and runs down normally but the indicator just seems to be stuck).", would be for me: https://www.kijiji.ca/v-cell-phone/g...one/1457092515
    Edit: G4 sold but he still got the S3
    09-05-2019 02:11 PM
  2. LettoLetto's Avatar
    Ok, so thanks to r/freedommobile & the device compatibility matrix on the website: https://www.freedommobile.ca/en-CA/s...hone--en--2--1
    I have it narrowed down to the following options at the moment:
    Open box LG Q6 (M703) for $121.99 ($137.85 after tax): https://forums.androidcentral.com/e?...token=iqEr2smi
    if I were to settle for 16GB of storage instead of 32GB there's a Open box LG X Power 2 for $2 less before tax, however when I went to look to see if it says if it's the M320G (Would be Wi-Fi Calling, VoLTE & Extended Range LTE compatible on BYOP), in item specifics it shows up as a Canadian Samsung Galaxy S7 (G930W8 ) that's not listed on the device compatibility matrix but from what I can see it's only lacking B66, it got B4, 7 & 13: https://forums.androidcentral.com/e?...token=cXYYsO2C
    If I had just another $7.50-$10 or so to cover the cost of tax, there's a Open box Condition C LG G6, though it don't say if it's the H873: https://forums.androidcentral.com/e?...token=L2Vy6tLS
    looked worldwide & there's a Open Box Moto G6 Play (XT1922-9) on the US side of Niagara Falls For $144.94 or best offer+$22.39 shipping with the current exchange rate, that would be about $2 less than the C Grade G6 & would be open to offers to get it in budget: https://forums.androidcentral.com/e?...token=BCd9YeKg
    Edit: Just checked my local Kijiji & here's some possible used options in the 16GB+ range if I were to settle for a 16GB instead of 32GB+:
    LG G6 64GB for $150: https://www.kijiji.ca/v-cell-phone/k...-g6/1457426797
    LG X Power 3 for $100: https://www.kijiji.ca/v-cell-phone/k...ked/1458164200
    LG X Power 3 for $100: https://www.kijiji.ca/v-cell-phone/k...r-3/1455656902
    eBay listing for a X Power 2 that's mixed up from the same seller from the one above, except instead of it being for $119.99 with some S7 mixed in, it's $89.99 with some K4(2017) mixed in: https://forums.androidcentral.com/e?...token=to7qM2EV
    They also have a Open box X Power 3(LM-X510WM) that appears to be a X Power 3 for $129.99: https://forums.androidcentral.com/e?...token=jJAWuZin
    Moto E5 Play for $70: https://www.kijiji.ca/v-cell-phone/c...lay/1448466032
    Multiple iPhone 6 options showed up in the $110 & $170 price range (I capped the search at $170 to offer up to $20% off),mainly regular 6 16GB but other variations (S & +) in 16GB or 32GB & up
    I also checked for the iPhone 7 & there were 3 results, $150, $165 & $170)
    from r/freedommobile I had 2 offers for a phone:
    If I had a way to get to Downtown Toronto, I could get a LG G6 that came from Freedom for $150, sadly I don't have a way to get there unless I take a Go/Greyhound bus
    A brand new unopened Samsung Galaxy A8 (2018) from Freedom, had been planning on $250 earlier, but they can do $150 for me. Happy to help out someone in need, they'll be passing by my city on the 17th or 18th
    09-09-2019 01:08 PM
  3. LettoLetto's Avatar
    Deal is done, I'm now the proud owner of a Used LG G6, met the seller at a Freedom Mobile store & before I paid for it got the store to test it & it passed, so I paid for it & brought it home, $150 Canadian w/ a Spigen case (looking at their site it looks like the Tough Armor): https://www.kijiji.ca/v-view-details...dId=1455562253
    09-11-2019 06:18 PM
28 12
  1. Buying my seven year old son a phone
    By LadyMabbey in forum General News & Discussion
    Last Post: 08-22-2019, 10:38 PM
  2. Restore recent apps under long pressed home button.
    Last Post: 07-31-2019, 08:21 AM
  3. Computer does not recognize broken Google Pixel phone.
    Last Post: 07-30-2019, 11:03 PM
  4. Replies: 1
    Last Post: 07-30-2019, 08:32 PM
  5. alcatel tetra waiting for device
    Last Post: 07-30-2019, 08:07 PM
