1. AllenRulz's Avatar
    Just got the phone and it's the first time I've seen this kind of power adapter. It has prongs at the end and then a separate little piece (says for travel on it) to connect into for the wall.
    Is this the normal way of really charging this phone? I want to make sure it's getting the full fast power to it like it should.
    I appreciate the help. Just not used to this type of setup.
    08-05-2019 11:11 AM
  2. Rukbat's Avatar
    No way to tell unless you a) post a picture and b) tell us what country you're in. There are too many plug types to guess.
    08-05-2019 02:48 PM
  3. AllenRulz's Avatar
    Here ya go. I'm in the United States. Xiaomi Mi 9T charger question???-1565043881631.jpeg
    08-05-2019 05:24 PM
  1. mi note 5 pro and was updated android 9 and super live pro app is not workin
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 08-03-2019, 03:01 PM
  2. Replies: 4
    Last Post: 08-03-2019, 12:58 PM
  3. Question about quick memo
    By Tenatioust in forum Ask a Question
    Last Post: 08-02-2019, 03:29 PM
  4. mi note 5 pro and was updated android 9 and super live pro app is not workin
    Last Post: 08-02-2019, 05:25 AM
  5. Plug in the box not fast charger?
    By kyleresq in forum Samsung Galaxy S10 & S10+
    Last Post: 07-31-2019, 07:37 PM
