1. AirMech74's Avatar
    I need a good phone holder for my truck...i've purchased a few and none of them really stay in place. I've seen the ones that use magnets. My question is....Does the magnet not affect the phone itself?...I always thought magents would wipe the phone or cause internal damage.
    Nostromo79 likes this.
    08-07-2019 07:33 AM
  2. hallux's Avatar
    Not a magnetic one but I have the iOttie OneTouch 4 mount and have been very happy with it. I'm not a fan of the magnetic mounts, I like clear cases (otherwise why would I care what color my device is?) so that magnetic disk on the back of the phone would be annoying to see.
    08-07-2019 07:38 AM
  3. notacoach's Avatar
    Love my Koomus magnetic holder - have used it, with a case, for my v20 and now v40. Currently I'm looking for one with Qi, but if you don't need charging I can highly recommend this mount! I have the one which goes in my CD slot and it is 100% stable. Never any issue with data or function, and the magnets have been strong enough to hold it extremely well through both a wallet case and a form-fitting Ringke.
    08-07-2019 09:33 AM
  4. Mooncatt's Avatar
    I've had one of theirs in the past and they tended to basically throw the phone out with a decent bump. I think the next one I get will be a RAM Mount.
    https://www.rammount.com/shop-all/to...s/phone-mounts
    You can buy a complete kit, but they are also modular so you can custom design the ideal holder and mounting setup. They also come with a tether for extra security, such as using on a motorcycle or other situation where a drop could cause loss or damage (as fragile as phones are today, any drop could cause damage).
    Beware the sticker shock, though, but they are high quality mounts.
    B. Diddy likes this.
    08-07-2019 10:07 PM
  1. How can I make the phone ring for calls and sms on headphones?
    By Andrew Brehm in forum Ask a Question
    Last Post: 08-08-2019, 11:19 AM
  2. How to remove 51happlay from android phone?
    Last Post: 08-07-2019, 05:54 PM
  3. How can I detect if the phone is locked by a password, pin or pattern?
    By Android Central Question in forum Developers Lounge
    Last Post: 08-07-2019, 05:52 PM
  4. Special contact entry in my car, to "phone" my phone. (Contact entry #voice search)
    By Michael Egglestone in forum General Help and How To
    Last Post: 08-06-2019, 01:27 PM
  5. phone is refusing update
    Last Post: 08-06-2019, 10:25 AM
