1. rspiet's Avatar
    I have noticed this after the most recent software update on my Galaxy S8+ and it is quite annoying. If I am trying add a contact to a text message, I start typing the contact name, the result list shows me the Contact Name and Telephone Number for each number that I have for the contact but it does not show me which one is Mobile, Home, Work, etc.
    For example, it shows me John Doe 123-123-1455 and John Doe 456-123-1456, when it should show John Doe - Mobile: 123-123-1455 and John Doe Home: 456-123-1456.
    I don't want to send a text message to a land line or the wrong phone. Is this just a defect in the App? Is there a better text message app that anyone would recommend?
    08-08-2019 05:18 PM
  2. Rukbat's Avatar
    If you keep the same format for all contacts (home, work, mobile - and if one is missing, enter it as 000 000-0000), you'll know that the 3rd number in a contact with 3 numbers is the cellphone number. (It's a "defect" in how Samsung implemented things - pure Android shows <a number> Work, <a number> Home, <a number> Mobile, etc.
    Try Google Messages.
    08-08-2019 05:32 PM
  3. mustang7757's Avatar
    I guess when you have multiple numbers for contacts it will show which you want to use as a default
    08-08-2019 05:32 PM
  1. messages + notifications
    By ansa82 in forum Samsung Galaxy Note 9
    Last Post: 08-16-2019, 10:20 AM
  2. unfortunately touchwiz home stopped
    Last Post: 08-08-2019, 05:34 PM
  3. Looking for a non-Appleified phone
    Last Post: 08-08-2019, 05:21 PM
  4. My gmail shows up..but when i choose to open email...it flashes and wont open.
    Last Post: 08-08-2019, 04:19 PM
  5. Replies: 3
    Last Post: 08-08-2019, 04:15 PM
