1. bignloud65's Avatar
    Hello! When I connect my ZTE Blade Spark to my car Bluetooth, and when I go to the "phone book" listing on my dashboard screen, I get a bunch of numbers that read "Suspected Spam", "Debt Collector", etc. Obviously not numbers that I have entered into my phone listings. I have tried multiple times to get rid of these numbers, including contacting Bluetooth and my car manufacturer. I have had no luck.
    Does anyone have any idea as to how to delete these listings from my Bluetooth phone book? There are quite a number of them, and it can take me forever to scroll through the listings to get to a contact at the end of the list.
    Thank you for any help!
    08-18-2019 02:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already tried forgetting the phone from the car system (and the car system from the phone), then going through the pairing process again?
    08-18-2019 03:41 PM
  3. bignloud65's Avatar
    Yes, I have tried that. I have tried almost everything, it seems like. I am totally unsure as to what to do. I might just have to live with it, I guess.
    I can't even bring up these listings on my phone to scroll through them and delete one by one.
    08-31-2019 11:39 AM
  4. mustang7757's Avatar
    Do you have another phone maybe paired to your car? Or previous.
    08-31-2019 11:46 AM
  5. bignloud65's Avatar
    The phone I have currently I have had for awhile now. I don't believe that my older one would still be paired. I believe my current phone is the only one paired to the car.
    08-31-2019 05:48 PM
  6. mustang7757's Avatar
    It's a long shot but double check , sometimes crazy things like that happens.
    08-31-2019 05:49 PM
  7. bignloud65's Avatar
    I'll try it out. Not even sure if the phone still has a charger or anything, but I'll see what I can do. Thanks for the tip!
    mustang7757 likes this.
    08-31-2019 05:58 PM
  8. mustang7757's Avatar
    Your welcome, let me know otherwise we see if can try anything else.
    08-31-2019 06:01 PM
  9. bignloud65's Avatar
    I had the chance to try to connect my old phone to my car. I was unable to. I actually don't even get anything to come up on my dashboard saying something like "connect" or "disconnect".
    09-18-2019 05:11 PM
  10. mustang7757's Avatar
    Maybe something going on with your car audio system?
    09-18-2019 06:40 PM
  11. bignloud65's Avatar
    It's quite possible. I have tried going through VW for help, but they said they don't know what the problem is. Maybe I should try them again...
    09-18-2019 09:07 PM
  12. Mike Dee's Avatar
    You should be able to see the phone in your car's bluetooth connections if its there
    09-18-2019 09:10 PM
  13. mustang7757's Avatar
    Sometimes disconnect battery for 10 minutes helps with issues like that (meaning car battery negative side)
    09-18-2019 09:12 PM
  14. bignloud65's Avatar
    When I bring up my Bluetooth menu in the car, the only options it gives me is the phone book, recent calls, etc. I can't get anything else to come up, like unpair phone or anything like that.
    09-18-2019 09:29 PM
  15. Mike Dee's Avatar
    There might be another system menu where you can delete your device.
    09-19-2019 05:11 AM
  16. bignloud65's Avatar
    Yeah, I've looked through the different menus, and I've even looked through the owner's manual. I can't find anything else!
    09-19-2019 05:57 AM
  1. My data going shut down during incoming/outgoing call
    Last Post: 08-18-2019, 04:39 PM
  2. Can I unlock a sprint galaxy s4 that's showing a error code?
    Last Post: 08-18-2019, 01:55 PM
  3. Replies: 3
    Last Post: 08-18-2019, 01:51 PM
  4. Why is my sons android tablet showing “no app found to open url”?
    Last Post: 08-18-2019, 01:47 PM
  5. Cant record viedo off my coolpad
    Last Post: 08-18-2019, 01:30 PM
