HTC 5G Hub Router Settings Page
Leontay Roberson
3
I'm trying to reach the settings page for the 5G HTC Hub from Sprint. I've tried 192.168.1.0, 192.168.128.1 and countless others. Nothing. Sprint doesn't know nor does HTC.
Does anyone know if the HTC 5G Hub even have this option?? The Coolpad Surf did, but apparently I can't find it for this this.
What are you trying to do from the settings page? Doesn't the hub have a system settings page, like a phone? That's what I gather from looking at the manual.
I'm guessing you can't do that on a device like this that is basically acting like a wi-fi hotspot (and not a true router). Let me see what @Rukbat thinks.
[URL="https://forums.androidcentral.com/e?link=https%3A%2F%2Fwww.kqzyfj.com%2Fclick-7301867-13098745%3Fsid%3DUUacUvbUpU6615133%26url%3Dhttps%253A%252F%252Fwww.htc.com%252Fuk%252Fsupport%252Fhtc-5g-hub%252Fhowto%252Ffirst-time-setup.html%2522&token=hKwVtz0r]This article[/URL] should get you started. It's not the typical "connect to the gateway address" router, but it is a router, from what I can see. (Maybe in 10 years, when I need one, I'll get one and see what it's like.) It's more like a cellphone hotspot, as far ac accessing it (you use the front panel). Not that a hotspot is anything other than a router, it's a router without a hardware switch.
This article should get you started. It's not the typical "connect to the gateway address" router, but it is a router, from what I can see. (Maybe in 10 years, when I need one, I'll get one and see what it's like.) It's more like a cellphone hotspot, as far ac accessing it (you use the front panel). Not that a hotspot is anything other than a router, it's a router without a hardware switch.
Can you reshare that link? It's causing the annoying affiliate link block by the forum software. Reshare the link, but this time within the edit screen, delete the https:// part, then highlight the rest of the link and click the Unlink button. That's the trick I figured out to make those links work.
AARRGGHH!!
See if this works - take out the spaces.
https: // www .htc. com /us/support/htc-5g-hub-sprint/howto/first-time-setup.html
(htc 5g hub connection in Google - the "setting up for the first time" link.)
sshkjgh7788
