Originally Posted by
Golfdriver97 Welcome to the forums. What command are you using? Have you tried rebooting into recovery by powering down and the pressing power and volume down?
The command I was using is
adb reboot recovery
Yes, I tried to boot into recovery mode using the power button and the volume down but it boots into fastboot. In fact when ever I try to factory reset my phone from settings my phone restarts and boots into a black screen saying recovery mode then it reboots into android without factory reseting the phone.
