1. pb5525's Avatar
    SAME OLD STORY ...I get a new phone, I like it. then the update happens and I have no speaker and no mic. I am using my phone only to txt! I have tried turning it off then on again. I tried a factory reset. I downloaded google sound. I have not rooted yet but that is next. Help! oh yeah, I have the Xiaomi Mi 8 Lite 6 GB ram/ 128 storage. USB c
    thx
    08-30-2019 03:22 AM
  2. mustang7757's Avatar
    thx
    Have you tried safe mode ?
    08-30-2019 08:21 AM
  3. B. Diddy's Avatar
    When you say you have no speaker, do you mean that no sounds play at all over the main speaker as well as wired or Bluetooth headphones? Are you certain all of the volume sliders are turned up?
    Which mic isn't working? Are people unable to hear you on a call? Is it the same issue on speakerphone? If you record a video, is there no audio recorded at all?
    Was the update an official one pushed over-the-air by Xiaomi, or did you download the file from some website and install it manually?
    08-30-2019 11:32 AM
  1. Website always assume I'm in the city of gridley wish I had no idea where it is
    Last Post: 08-30-2019, 06:18 AM
  2. lg g2 firmware stuck at 0 (no root)
    Last Post: 08-29-2019, 11:22 PM
  3. Samsung S8 Active no upgrade path plus case reccomendations
    By whitie iii in forum Ask a Question
    Last Post: 08-29-2019, 01:04 PM
  4. Missing/No voicemail app - new N10+ from microsoft store - verizon
    By bbb bbb in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-29-2019, 10:36 AM
  5. Why does my phone say no network connection when i have mobile data
    Last Post: 08-28-2019, 09:06 PM
