1. Delmar Barnwell's Avatar
    Trying to use my RCA viking pro tablet on my aristo 2 mobile hot spot...i have hot spot and the usb tab dont come on when i turn hot spot on...what do i need to do get run tablet off my hot spot on phone
    09-01-2019 07:50 PM
  2. hallux's Avatar
    Why can't you use WiFi tethering?
    09-01-2019 08:10 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree with hallux -- wi-fi tethering would be easier.
    Are you sure your phone is capable of USB tethering? See if you can find the option here: https://support.t-mobile.com/docs/DOC-37781
    09-01-2019 08:18 PM
  1. How to get Verizon caller ID identification on unlocked 10+?
    By Misterb in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-10-2020, 12:25 AM
  2. Dark Mode for Outlook on Android
    By gernerttl in forum Android Apps
    Last Post: 04-26-2020, 12:12 PM
  3. Why does android have a solid black circle on it in upper right corner
    Last Post: 09-01-2019, 08:27 PM
  4. I cant get out of children mode on my sons tablet
    Last Post: 09-01-2019, 08:26 PM
  5. Force use of AUX even when Bluetooth is enabled
    By hathzaer in forum Ask a Question
    Last Post: 09-01-2019, 05:50 PM
