1. Notey9's Avatar
    Whenever I play an episode of a show on Netflix, on my note9, it just stops at the end of the show and the next one doesnt automatically come on, this is only a recent thing I've noticed. And yes the autoplay function is enabled.
    09-15-2019 06:24 AM
  2. mustang7757's Avatar
    Hi, welcome!
    I would try clearing cache,data and force stop the app see if it corrects it.
    09-15-2019 10:04 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum since the former is intended for developers to promote their apps.
    Did this only start after a recent update? If so, send some feedback to the developer. Are you able to compare this behavior on different devices?
    09-15-2019 12:58 PM
  4. B. Diddy's Avatar
    Duplicate threads merged.
    09-15-2019 01:25 PM
  1. Audio Volume on 10+
    By onthehunt in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-04-2019, 10:51 AM
  2. why is my settings not start
    Last Post: 09-15-2019, 01:24 PM
  3. Mi 9t. Max settings heavy gaming on Snapdragon 730 question?
    Last Post: 09-15-2019, 03:10 AM
  4. Why is my instagram not opening
    Last Post: 09-15-2019, 02:05 AM
  5. Mobile Data Turned off Notification on Note 10 plus
    Last Post: 09-15-2019, 12:43 AM
