1. Kaiama's Avatar
    Left the phone on charge overnight. Only showing 46%. Then took battery out for 5 minutes. Put battery back in. Now showing 82%. Notification shows charging 82%. Icon at screen top right shows almost white battery with dark lightning zigzag. I think it is charging but it hasn't moved to 83% after 10 minutes. I have turned down screen brightness to around 65%.Not sure if it is charging or charging but not showing on the screen properly. Help! Its the wife's phone and I'm desperate!
    09-15-2019 06:29 AM
  2. mustang7757's Avatar
    Hi , welcome !
    Sounds like a battery issue , since you can remove it , I would try that first.
    09-15-2019 10:03 AM
  1. Chrome not opening Youtube link
    By dbbr in forum Sony Xperia XA2
    Last Post: 09-15-2019, 06:32 PM
  2. why is my settings not start
    Last Post: 09-15-2019, 01:24 PM
  3. Why is my instagram not opening
    Last Post: 09-15-2019, 02:05 AM
  4. Picture in Picture not working
    Last Post: 09-15-2019, 12:07 AM
  5. My Battery :(
    Last Post: 09-14-2019, 01:05 PM
