1. bkenobi69's Avatar
    I just upgraded my phone to an A10e running stock 9/Pie. The lock screen image I use has white background in the top 1/3 and the notification icons are all white making them almost invisible. I changed the clock/date text to black but how do I change the icon color to anything other than stock white?
    Jeremy Hendrix likes this.
    09-16-2019 03:58 PM
  2. Jeremy Hendrix's Avatar
    Same problem...if you come across a solution
    09-30-2019 10:30 AM
  3. bkenobi69's Avatar
    I was told by AT&T store I need to change my background. Not cool, but I guess an option.
    09-30-2019 12:20 PM
  4. B. Diddy's Avatar
    I moved this from the Oreo forum (you mentioned the phone is on Pie) to the General Help forum. We don't have a dedicated A10e forum, and the OS version forums are intended more to discuss general features of a given version across phones, not device-specific ones like this.
    Try Good Lock: https://www.androidpolice.com/2019/0...-apk-download/
    09-30-2019 12:37 PM
  1. Screen Fast Blinks
    By Marky Magnifico in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-22-2019, 12:58 PM
  2. Edge lighting notifications not seeming to work
    By rushmore in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-18-2019, 03:56 PM
  3. S4 Mini keeps turning screen on.
    By 2CV67 in forum Samsung Galaxy S4 Mini
    Last Post: 09-16-2019, 07:17 PM
