1. thee_explodingboy's Avatar
    I received the Pie update last week and as soon as I updated my HTC U11 I began experiencing audio playback issues specifically on Snapchat and Instagram.
    When I record a Snap or Instagram video and there is music playing either from my phone or in the car the audio for the music only sounds muffled and only has drum and symbols prominent in the recording, the bass and guitars sounds like they're underwater. I've tested this with and without me speaking and the issue is the same.
    When I playback what I just recorded it plays about 1 second of crisp clear music and then you hear the quality drop and turns into the issue I described above.
    I've tested my phones video camera and it records and plays back the music without any issues.
    I've had about 3 updates for each app since and I test it with both apps and no luck. I've cleared the cache, restarted my phone, re-installed the apps but the issue persists. Does anyone have any suggestions or ideas of what it may be? Is anyone else experiencing this?
    09-18-2019 03:41 AM
  1. Chrome pop-ups since Android 9
    By Colmss in forum Samsung Galaxy Tab S3
    Last Post: 09-19-2019, 01:03 AM
  2. Always On Display Update Available
    By strikeIII in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-18-2019, 11:06 PM
  3. How to force app to be installed to SD card - Android Oreo
    Last Post: 09-18-2019, 04:42 PM
  4. How to disable HDR when use camera2 api in android app
    Last Post: 09-18-2019, 03:30 PM
  5. How to prevent apps from autostart Android OREO Samsung S7
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 09-18-2019, 02:48 PM
