1. UberMongoose's Avatar
    So after doing the repair, I realized that while using the phone, it would seem to randomly go into standby, as though I had just hit the power button, except with vibration as though I hit a navigation button. I eventually identified 2 vertical invisible lines near the bottom of the screen which, if swiped over left, and only left, result in this happening. I'm baffled, does anyone have any ideas?
    09-26-2019 07:47 PM
  2. Rukbat's Avatar
    Take the phone apart, diagnose what you broke, fix it and put it back together. If you can't do that, bring the phone around to repair shops and see if any reputable one will accept it for repair, and if they'll give you an estimate for a reasonable price. Otherwise, replace the phone.
    This is why I strongly suggest that replacing a screen is not a DIY repair job. If you can't diagnose the problems you cause, you shouldn't be replacing screens.
    09-27-2019 01:00 PM
  3. UberMongoose's Avatar
    I have to ask Rukbat, did you actually type that response, or is it just your stock answer to any screen replacement issue?
    09-29-2019 02:00 AM
  4. Rukbat's Avatar
    No, I actually typed it. If you're experienced enough to be replacing parts inside the phone, you shouldn't have needed me to tell you. If you needed me to tell you, I just pointed out that you can't repair the phone. A "simple job" like replacing a screen isn't simple, you need experience. (I used to own cellphone repair shops. It usually took a trainee, who already had electronic troubleshooting experience, a month or two to get to the point that I'd let him work on a customer's phone.)
    09-29-2019 03:53 PM
  1. Replies: 2
    Last Post: 09-29-2019, 03:55 PM
  2. Lowlight pictures. Mate 20 Pro, P30 Pro and Note 10+ .
    By rikken in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-28-2019, 08:30 AM
  3. AOD and Lock Screen after a restart?
    By donb2010 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-26-2019, 09:29 PM
  4. Widgets broken after update?
    By Mooncatt in forum LG V20
    Last Post: 09-26-2019, 02:29 PM
  5. Replies: 1
    Last Post: 09-26-2019, 06:59 AM
