1. CocoBZ's Avatar
    I have a Moto G5 Plus, and when it reaches 15% battery I receive no alert message or sound, so I can miss it if I'm not using the phone, which lead to me finding the phone turned off on a number of occasions because of it. I found nothing in settings and I don't want to use a third party app.
    10-16-2019 04:56 AM
  2. Galactic Zoo's Avatar
    Try resetting app preferences Settings > Apps > three dots > Reset app preferences > Reset apps.
    Got this info from the Lenovo forum and seems to work
    Laura Knotek likes this.
    10-16-2019 06:51 AM
  3. CocoBZ's Avatar
    Tried it, no luck.
    10-17-2019 05:20 AM
  4. methodman89's Avatar
    Try Battery Notifier BT from the play store. You'll be able to set limits with notifications.
    Good luck
    10-17-2019 07:51 AM
  1. Replies: 3
    Last Post: 10-17-2019, 10:49 PM
  2. Cannot setup email account on Note 2
    By andalusite in forum Samsung Galaxy Note 2
    Last Post: 10-17-2019, 02:11 AM
  3. Replies: 1
    Last Post: 10-16-2019, 05:08 AM
  4. Why cant i send a vid that is only 50 secs long to friends on messenger?
    Last Post: 10-16-2019, 01:43 AM
