1. ctrippy1's Avatar
    I looked on amazon and then read a little about quick charging and now I'm totally confused as to which charger will quick charge my phone. Help??
    Actually what i need is a 6 ft cable to work with factory wall unit.
    10-29-2019 10:44 AM
  2. anon(10614692)'s Avatar
    YOu need the one that came with the phone if you want fast charging or an OEM replacement
    10-29-2019 12:00 PM
  3. Rukbat's Avatar
    Any 18 Watt (or higher) charger, any cable that can fit the charger on one end and a Type C connector on the other. (I recommend braided cable. Still cheap, but good.)
    10-29-2019 12:19 PM
  4. ctrippy1's Avatar
    Thank you for your help.
    10-29-2019 07:31 PM
  1. Note 9 issues with Samsung music app?
    Last Post: 10-29-2019, 01:12 PM
  2. do sim cards deteriorate over many years?
    Last Post: 10-29-2019, 01:07 PM
  3. My granddaughter removed my facebook icon and i need it back
    Last Post: 10-29-2019, 07:53 AM
