Android os marshmallow apk how do I get that off and how can I tell if it's hidden
Printable View
Hi,welcome
Android marshmallow not a APK it's your software , what phone you have ?
Welcome to Android Central! The OS is the firmware. APK files are installer files for apps. Are you saying that you want to downgrade your phone from Marshmallow back to Lollipop? That's inadvisable, considering how old Lollipop is and how it will soon become incompatible with more and more apps.
