Android 9, Ulefone Armor 6S, music stops playing after screen lock
MonstroMorini
10
Hi guys,
very happy with my new phone. However, i a have an issue that i have not been able to solve....
Music stops playing when my screen lock kicks in, it doesn't matter which app, tried several.
Have also in the advanced battery saving options excluded all these, no result.
And have now disabled any battery saving, no result.
When on the wireless charger, music keeps playing, so hence my susption of some "saving" intelligence
that is killing my output....
And related: how do i switch output (internal speaker <> bluetooth speaker/inears? I only have this option
when placing/receiving a call. None of my music apps give me this possibility.
apps tested: standard google play, aha radio (yes, i am so lucky to own a kenwood dab car-receiver.... not),
vlc, audify, music player....
Some Chinese brands have a very aggressive memory management that could cause such kind of issues. Have you checked your memory/RAM settings? Are you using any third party memory booster or cleaner app?
Settings>Apps>{app name}>Battery>Optimize Battery Usage
Switch the view from "apps not optimized" to "All", find your app and DISABLE battery optimization
Yes - that I have done already. Have also tried shutting down any battery optimalisation. And tried the "hi-performance" setting.
Alas , to no avail.
Does this also happen with the stock music app? I'm not sure if the list you mentioned includes the stock app.
The stock player is the Google Play Music app. It stops, thats why I tried other apps. Only manufacturer app is a tool box (with uv-meter, compass, barometer etc) and a "sim-toolkit" (that does not respond - "not activated or installed) plus a game mode, that i haven't used.
Will try the PowerAudio and report.
PS: found a sleep timer in Google Play Music - was not set, so also not the problem, alas. Power Audio also stops.
Maybe try an app like Stay Alive! to keep the screen on? Or does the music app stop whenever the screen locks, regardless of whether or not the screen is actually on?
Yes, any music app stops playing after screen locks, after about a minute. When on the charger it now also stops.... sh^%%$t. (Sorry... but now no more music in the car when in the wireless charging holder.)
Setting f.i. (translated from my dutch version of Pie) Google Play Music: background usage - no limitation, battery optimizing - not optimized.
Ofcourse tried the battery enhanced setting as well, no difference.
And playing bluetooth --> earbuds, or just the builtin speaker makes no difference. Screen locks, after 60 seconds music stops.
Have set the sleep timer in Google Play Music to a few hours - music stops :(
Unfortunately, it may just be an issue with Ulefone's firmware. You can try contacting their support, but the challenge with these lesser known Chinese manufacturers is the relative lack of support.
Yep, you are right about their support! They only offer a return form in case the hardware fails, the rest is up to the user. Well i got what i paid for ;)
On the bright side: my experience with problems/service on one of my Apples was also terrible.
Over the xmass period I will try a clean install, since it worked fine the first few days. But is a pain, since I mainly use it for navigation on my bike.... downloading all maps takes forever.
For the "switch to Bluetooth", you can try BTmono. I've used it for apps that won't switch, and it works.
Thx!!
And solved the problem!!!: It was the "Equalizer" app.... ditched it and the music keeps playing :-*
Excellent! Thanks for the follow up, it'll be very helpful for other users with a similar issue. Which equaliser app was it?
I think - but since I uninstalled it can not check- it was the IJoysoft version, but since they share the same "icon", it could also have been the Kucap version.
HENRYBOY
