1. JimRaginCajunScot's Avatar
    My phone had to be reset!
    All of my Samsung notes are gone!!
    Is there any way to save or backup to avoid this in the future!?
    12-02-2019 02:52 PM
  2. SpookDroid's Avatar
    If you're using Samsung Notes, make sure the cloud backup option (to your Samsung Account) is active, otherwise the notes are only stored locally on your phone and any factory reset will automatically wipe out those files with no way to recover them.
    Alternatively you can export these to other file formats for manual backup to cloud storage or copying to external storage/PC.
    12-02-2019 03:16 PM
  3. Joshua Luther2's Avatar
    I'm looking for a way to transfer my S9 Notes to my Pixel 4 XL coming today. The onlu way I've found is to send them via email in the form of PDFs to myself. I can then open them and copy and paste them into the general Note app of my choice. Unless I am able to download the Samsung Note app on my Pixel.
    12-04-2019 07:20 AM
  4. SpookDroid's Avatar
    Unfortunately that is correct. You can use the Samsung Notes app in certain Windows 10 computers (Samsung ones) but that's about it. I miss the time when you could sync the notes to Evernote, but that partnership is long gone. Now all you can do when moving to a non-Samsung phone is to manually export all notes and transfer them manually either through a cloud service or data transfer.
    That's why, even though the feature set isn't great, I've sticked to using OneNote for note taking now, since it pretty much syncs with everything.
    Joshua Luther2 likes this.
    12-04-2019 09:44 AM
  1. T-Mobile 5G Note orders are live-Uses x55 Modem!
    By TechBob in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-05-2019, 10:31 AM
  2. S9 (very fast!) pics take so long, if ever, to reach the cloud! Why!?
    By JimRaginCajunScot in forum General Help and How To
    Last Post: 12-02-2019, 11:18 PM
  3. My Samsung S9 (very fast!) pics take so long, if ever, to reach the cloud! Why!?
    Last Post: 12-02-2019, 03:10 PM
  4. Where to find the wps push button in Samsung a10
    Last Post: 12-02-2019, 02:40 PM
  5. Can you build a website on a samsung tablet
    By Android Central Question in forum Samsung Galaxy Tab S6
    Last Post: 12-02-2019, 01:06 PM
