1. ScttLee184's Avatar
    Is there anyway to have my "simple calender" agenda widget show on the lockscreen? Or recommended calendar app that can. I can get Google calendar to send event notifications only not an agenda list.
    01-23-2020 04:32 AM
  2. Kirstein Gourlay's Avatar
    Hi Scott. As far as I am aware widgets are no longer supported on Android Lockscreen, however, I am not 100% sure. I believe you can only have notifications on the Lockscreen.
    Please tell us what phone you are using and what version of Android it is running and we may be able to give you a clearer answer.
    01-23-2020 06:03 AM
  3. Don R S's Avatar
    I can't set or change my screen Lock from swipe to a PIN or a password. it acts like it's is there is no error or anything. and when I try it it is still on swipe
    01-23-2020 06:26 AM
  4. ScttLee184's Avatar
    Moto x4 Android 9.
    01-23-2020 07:09 AM
  5. B. Diddy's Avatar
    How about Calendar Notify?
    01-23-2020 11:35 AM
  6. B. Diddy's Avatar
    Duplicate threads merged.
    01-23-2020 11:58 AM
  7. ScttLee184's Avatar
    Thanks. Strange that 3rd party calendar apps don't put their widget on the lock screen when many audio players can & do (even if only while playing).
    Sorry for duplicate posts. When I post I get a full screen of errors, try to post again and the same error, try a 3rd time and it says already posted.
    01-24-2020 10:37 AM
  8. B. Diddy's Avatar
    There's no such thing as lockscreen widgets any more (I think that was only for KitKat). The things you see on the lockscreen are technically lockscreen notifications, so you need to look for a 3rd party calendar app that has a lockscreen notification in the form of an agenda.
    01-24-2020 11:22 AM
  1. Spotify nothing on the lockscreen
    By Steve Frost36 in forum Huawei P20 & P20 Pro
    Last Post: 02-01-2020, 03:53 PM
  2. Lockscreen calendar widget
    By ScttLee184 in forum Ask a Question
    Last Post: 01-21-2020, 11:58 AM
  3. How do you get rid of a weather widget on a LG Escape2?
    Last Post: 01-19-2020, 05:41 PM
  4. Widget not working after Android 10?
    By 9ko in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 01-18-2020, 11:23 AM
  5. How to restore lost widgets from the widget site, i.e. the clock with weather.
    Last Post: 01-17-2020, 03:54 PM
