Does anyone else have issues with Mytouch 4G screen freezing when the phone rings so you can't slide the screen down to answer the call?
At least a few times per day, with different phone numbers, the phone will ring but I can't answer it because I can't slide my screen down, only up to decline.
Here's what I've tried, usually every day, all of them, and still it happens:
Popping the battery out and restarting the phone.
Restarting the phone without popping the battery out.
Using app killer all the time so that a minimum of 325M memory is available.
Then, I use Car Dock to answer the phone but IT DOESN"T RING SO I MISS THE CALL ANYWAYS!!
In the past I have reset the phone-I use My Backup Pro to back up my apps and data and then reset it. Nothing works. I got a new MyTouch and the same thing happened after I had had it for a week.
HELP!!!!
HELP!!!!
