Hello,
I've been having issues with my push notifications for a while, and finally isolated the cause - for some apps they're working and for others they aren't, but I've found if I go into settings, battery, battery usage and look down the list of apps (when they're all closed) some are marked "stopped" (the ones which aren't producing push notifications) and others are marked "running" (those which are working correctly).
From this I can only assume that the ones marked "stopped" (including discord and twitter) aren't running in the background and this is why they can't send push notifications, whilst ones marked "running" (such as gmail and facebook messenger) are running in the background and so they can.
BUT if I go to apps, select a "stopped" one and then go to its power usage details, on app launch they all state "background activity not restricted" - so how do I prevent them from being stopped so I can get notifications from them?
I've attached images of the key screens in case - all battery optimization settings are disabled as well.
Thank you in advance!
