1. cfaulkner3142342's Avatar
    Hello,
    I've been having issues with my push notifications for a while, and finally isolated the cause - for some apps they're working and for others they aren't, but I've found if I go into settings, battery, battery usage and look down the list of apps (when they're all closed) some are marked "stopped" (the ones which aren't producing push notifications) and others are marked "running" (those which are working correctly).
    From this I can only assume that the ones marked "stopped" (including discord and twitter) aren't running in the background and this is why they can't send push notifications, whilst ones marked "running" (such as gmail and facebook messenger) are running in the background and so they can.
    BUT if I go to apps, select a "stopped" one and then go to its power usage details, on app launch they all state "background activity not restricted" - so how do I prevent them from being stopped so I can get notifications from them?
    I've attached images of the key screens in case - all battery optimization settings are disabled as well.
    Why is Huawei P Smart stopping apps running in background when it shouldn't be?-screenshot_20200127_232933_com.huawei.systemmanager.jpgWhy is Huawei P Smart stopping apps running in background when it shouldn't be?-screenshot_20200128_000533_com.android.settings.jpgWhy is Huawei P Smart stopping apps running in background when it shouldn't be?-screenshot_20200128_000545_com.huawei.systemmanager.jpg
    Thank you in advance!
    01-27-2020 06:09 PM
  2. B. Diddy's Avatar
    This is not surprising for Huawei. Chinese manufacturers like Huawei tend to be pretty aggressive with RAM management for the sake of saving battery (but without much regard for how an app is supposed to work). Unfortunately, Samsung seems to be jumping on this bandwagon to a certain extent recently. See this site: https://dontkillmyapp.com/huawei
    01-27-2020 06:13 PM
  3. cfaulkner3142342's Avatar
    I've been having issues on my P Smart (EMUI 9.1, Android version 9). For all my apps background running/data usage is allowed, all battery saving/optimisation modes are disabled, all apps have been set to "don't allow" (battery optimisation to stop them from running) and all have notifications enabled. However I'm only getting push notificatons from them sometimes, and I've found why - if I close everything and go to look at battery usage, some apps are marked "stopped" and others "running" and these change seemingly at random, hence why I only get push notifications sometimes - but like I said, all my settings shouldn't be allowing this to happen. Any suggestions on how to fix?
    01-28-2020 04:28 AM
  4. B. Diddy's Avatar
    I merged your similar threads. Did you look at the link I shared above?
    mustang7757 likes this.
    01-28-2020 10:35 AM
  5. Rukbat's Avatar
    Some apps (like whatever your default email app is) will run when the phone receives a push notice (apps don't send pushes, they receive them), because anything coming in from the internet on port 110 or 993 is going to be email. But unless there's an official port for a service, there's no way for the phone to know to run the app (which app should it run?), so the app has to be running and watching the port number it's supposed to watch.
    B. Diddy's link will keep those apps that don't "wake up" from being killed.
    01-28-2020 05:23 PM
  1. Why is my Android TV keep going to this screen
    By Android Central Question in forum Android TV
    Last Post: 11-29-2020, 02:55 PM
  2. How do i Allow / Enable Photo Duplicates in google photo ?
    Last Post: 01-28-2020, 09:30 PM
  3. Why is my huawei suddenly getting no push notifications after reset?
    Last Post: 01-27-2020, 05:52 PM
  4. What is epdg mms xcap tmus
    Last Post: 01-27-2020, 05:42 PM
  5. Duplicate Street Addresses in Contacts
    By night66owl in forum Samsung Galaxy S10e
    Last Post: 01-27-2020, 05:05 PM
