1. firemcd's Avatar
    I have a LG Stylo 4 fully updated as of today. When I press my home button the shortcuts box pops up and this drives me crazy. Cannot find any option to get rid of it. Screenshot here.
    https://ibb.co/1Rc5Y9j
    Thank You !
    01-29-2020 12:26 PM
  2. SpookDroid's Avatar
    Are you using Nova Launcher? If so, just open the launcher's Settings, go to Gestures & Inputs and assign NONE to the Home Button action.
    Javier P, B. Diddy and firemcd like this.
    01-29-2020 12:36 PM
  3. B. Diddy's Avatar
    Or if you're using any other 3rd party launcher, look for a similar option in its settings. Your screenshot doesn't look like the stock LG launcher, judging by the fact that you seem to be using custom icons (although I could be wrong -- I haven't used an LG phone in a while).
    firemcd likes this.
    01-29-2020 12:41 PM
  4. Javier P's Avatar
    I agree with Spook, that looks like Nova's app search.
    B. Diddy, SpookDroid and firemcd like this.
    01-29-2020 12:45 PM
  5. firemcd's Avatar
    You kind folks hit it out of the park! Solved! It was most definitely a Nova Settings Issue. Changed the title to reflect "Solved". Thank You so very much.
    Javier P, SpookDroid and B. Diddy like this.
    01-30-2020 11:45 AM
  6. Javier P's Avatar
    Excellent! Glad it helped and thanks for the follow up.
    01-30-2020 11:50 AM
  1. Replies: 6
    Last Post: 01-29-2020, 06:39 PM
  2. As soon as I plug charger in the table automatically comes on AND won't turn off
    By Sondra Vandeventer in forum General Help and How To
    Last Post: 01-29-2020, 11:35 AM
  3. Why my P20 Lite has a non-stop ringing tone?
  4. Replies: 8
    Last Post: 01-29-2020, 11:29 AM
  5. Replies: 1
    Last Post: 01-29-2020, 03:14 AM
