1. missionsparta's Avatar
    I am using a Samsung Note 10+ with a uConnect and Android Auto. I get text notifications but when I hit okay, I just got the Google circles twirling and it never audobly reads it. Any suggestions?
    02-12-2020 01:19 PM
  2. B. Diddy's Avatar
    I moved this from the Android Apps forum to the General Help forum since the former is intended for developers to promote their apps.
    Is this on the uConnect interface on the dash screen, or does the screen show the Android Auto interface?
    02-12-2020 01:30 PM
  3. missionsparta's Avatar
    Thanks for the help instead of just deleting it. This occurs with the Android Auto Interface on the screen.
    02-12-2020 03:46 PM
  4. B. Diddy's Avatar
    Go to Settings>Apps, select Android Auto, and make sure it has permission to access your SMS. Also, check with your dealer or the uConnect website to see if there are any firmware updates to uConnect.
    kikbxr1969 likes this.
    02-12-2020 05:24 PM
  5. missionsparta's Avatar
    ok. I think I figured out what is going on. I think my Galaxy watch is making itself priority over Android auto for my messages. how do I set Android auto as the priority over my watch?
    02-14-2020 12:34 PM
  6. B. Diddy's Avatar
    I'm not sure if there's a way to do that. This kind of competition between Bluetooth devices can be a pain sometimes. So it works if you temporarily disconnect your Galaxy Watch from the phone?
    02-14-2020 02:17 PM
  1. ESR Cases and Charging Adapter Pre-order Discounts
    By Mike Dee in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 02-18-2020, 09:29 PM
  2. Note 9 dual SIM on Verizon and AT&T, need some help.
    By cgr1971 in forum Samsung Galaxy Note 9
    Last Post: 02-17-2020, 10:03 AM
  3. Schedule text messages disappeared- note 8
    By Nat2 in forum Samsung Galaxy Note 8
    Last Post: 02-14-2020, 08:47 PM
  4. I too often can't do voice calls and tells me, "call completed"
    Last Post: 02-12-2020, 01:55 PM
  5. Unlocked my Tmobile Galaxy S9 to get Android 10 update faster.
    By Chadlessness in forum Samsung Galaxy S9 & S9+
    Last Post: 02-12-2020, 12:43 PM
