1. SaurabhUd's Avatar
    My handset Samsung A70 is facing problem of Android System: USB connector connected - disconnected. Also phone when locked then still light is continuously on and draining my battery quickly. Please can you help me to fix it asap
    03-01-2020 03:17 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Make sure the USB port is clear of debris -- blow it out with a can of compressed air, and clean the contacts with a Q-tip dipped in rubbing alcohol. Also, have you tried a different cable?
    Are you saying that phone screen never turns off, even after it's been idle for a long time?
    P.S. I moved this from the Galaxy A5 forum to the General Help forum, since we don't have an A70 forum.
    03-01-2020 01:03 PM
  3. mustang7757's Avatar
    I would also try in safe mode
    03-01-2020 01:58 PM
  4. belodion's Avatar
    4d later.
    Presumably all is now good.
    03-05-2020 02:35 PM
  1. smartbulbs not connecting
    By me just saying in forum Amazon Echo
    Last Post: 03-04-2020, 03:43 AM
  2. Samsung S20 Ultra Battery Life Test..120hz
    By jimjonesG7 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-02-2020, 08:57 PM
  3. J'ai perdu mes samsung notes
    Last Post: 03-02-2020, 02:46 PM
  4. Replies: 1
    Last Post: 03-01-2020, 09:58 PM
  5. Samsung Galaxy S6 or G920
    By Jelldc in forum Ask a Question
    Last Post: 02-29-2020, 02:24 PM
