1. DJ TM7's Avatar
    Hi,
    Having an issue to where my iPhone XS Max is not connecting to iTunes anymore for anything, including a backup.
    That said, I am trying to find a way to export everything from my iPhone (Contacts, Text Messages, Documents, Videos, Pictures, Apple Notes [if even possible] and especially music to X Place to then put on the Galaxy S20 Ultra.
    I think the inability to connect to iTunes is a USB port issue, but I don't even know if iTunes would sync with the S20.
    Any help would be greatly appreciated before I send the iPhone back to Samsung.
    Thanks!
    03-10-2020 10:09 AM
  2. mustang7757's Avatar
    Connect the 2 phones with smart switch app on the s20iTunes (and everything else from an iPhone) to S20 Ultra-screenshot_20200310-101957_smart-20switch.jpegiTunes (and everything else from an iPhone) to S20 Ultra-screenshot_20200310-102008_smart-20switch.jpeg
    03-10-2020 10:21 AM
  3. anon(10614692)'s Avatar
    03-10-2020 10:23 AM
  4. B. Diddy's Avatar
    Not sure how much longer this feature will be around, since Google is slowly transitioning from Google Play Music to YouTube Music, but I think you can still upload your entire iTunes library to your Google Play Music library: https://support.google.com/googlepla.../1075570?hl=en. I did this a number of years ago, and it worked great (although be aware that it can take more than a day to upload everything, depending on how much music you have).
    And even though Google is making the transition, they have promised that a person's uploaded GPM library will be preserved and transferred over as well.
    03-10-2020 11:43 AM
  5. mustang7757's Avatar
    Also I forget to mention smart switch tool on computer can restore iTunes back up if you had previous ones alsoiTunes (and everything else from an iPhone) to S20 Ultra-20200310_114515.jpeg
    B. Diddy and aximtreo like this.
    03-10-2020 11:46 AM
  1. Unsupported format (wav and mp3) from Recording Studio
    Last Post: 03-12-2020, 03:28 PM
  2. "Regular" s20 Great Upgrade to s10
    By CincyGuy in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-10-2020, 10:29 PM
  3. My phone make an unknown "notification" when connected to internet
    Last Post: 03-10-2020, 07:53 PM
  4. 120hz and Amazon Prime
    By jtcannonball in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-10-2020, 11:53 AM
  5. How to get Samsung video player on p30 Pro
    By spinachie in forum Huawei P30 & P30 Pro
    Last Post: 03-10-2020, 10:34 AM
