Originally Posted by
Morty2264 I see you are a newer user here - welcome to Android Central!
Phone batteries unfortunately age around that timeline that you gave earlier - even though you did a good job in taking care of it. A year and a half is usually when my current phones start to show their age with regards to battery performance, as well.
Is everything else working as it should for you with your S9?
Thanks, yes everything else with the performance seems to be fine. And as I mentioned the overall battery usage seems pretty good. At least according to the phones meter, it only uses about 30% of the battery in a 24 hour period. Of course if the battery has really lost 30% of its total capacity the actual usage might not be as good as the meter indicates...
I have two family members who bought the same phones at the same times and haven't had this issue, and they weren't as careful as I was with charging. Anecdotal, I know, but I guess that's a part of why I'm surprised at what happened to mine.
