For phones that have front fingerprint sensor under the display (e.g. Note 10), how do you unlock the phone if the phone screen is cracked?
If the phone is cracked (fingerprint/pattern/pin do not work), how do you unlock it and save/backup/copy data to your pc before you send the phone for repair?
Whenever the phone is connected to PC via USB cable, the phone needs to be unlocked then the phone files will appear on PC Windows 10.
Thanks
Thanks
