1. Tuga1978's Avatar
    Hello, my name is Marco Silva.
    I'm a software tester and currently my colleagues are testing a Coship Set Top Box with Android software. They have run a set of CTS and GTS tests, and some of them failed. I was tasked to map which of the tests failed but i'm having some troubles doing it. For example, in the list of modules that failed, the armeabi-v7a CtsActivityManagerBackgroundActivityTestCases and armeabi-v7a CtsAlarmManagerTestCases were two of them, with one and two tests failed respectevely. How can i map on each module which tests actually failed? I have installed the android cts on my laptop even though i can't run it, since it only runs on linux or mac, but i can see that each pack of tests cases is a Apk file. I've already installed Android Studio to try to open the apk files in order to try to map their contents, but still i'm having problems trying to map the tests each apk file contains. Does anyone have some insight on this?
    Thanks
    03-24-2020 06:45 AM
  1. My S10 has been flashed with an unauthorized software and is locked
    By jerarudojunia in forum Samsung Galaxy S10 & S10+
    Last Post: 03-24-2021, 03:57 PM
  2. Pixel 3 and Google photos
    By patruns in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 04-15-2020, 11:48 AM
  3. $200 off US Unlocked model - S20 and S20+ on Amazon and Best buy
    By bhatech in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-27-2020, 11:32 AM
  4. How do you unlock phone if the screen is cracked?
    By acsurfer in forum General Help and How To
    Last Post: 03-24-2020, 10:26 PM
  5. Anyway to get Google Sans font?
    By fernandez21 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-24-2020, 01:32 AM
