1. Dick Veitch's Avatar
    I have a Samsung S5. I installed an endoscope camera and RealVisor Endoscope app to run it. Works fine. But it puts a panel "My Web Server http://100.107.225.149:8110" on the phone. It should not need any web connection. I can't remove this panel. Can somebody tell me more please?
    The camera is plugged into the Samsung so does not need any web connection. I can remove the "My Web Server....." panel by re-booting the phone but there must be a better way to do this.
    03-26-2020 03:39 AM
  2. anon(10614692)'s Avatar
    I guess this is used for a direct connection to the camera. Worth checking your manual for confirmation
    03-26-2020 03:52 AM
  3. Dick Veitch's Avatar
    Thanks. Got it sorted. The software is intended to respond to remote devices like doorbells and motion detectors - hence the web connection. The camera is wired to the phone. The web connection can be switched off but does not vanish from the phone until the phone is restarted
    B. Diddy and anon(10614692) like this.
    03-26-2020 07:07 PM
  1. The device or the app, this is a debate, sort of...
    By VidJunky in forum Samsung Galaxy S10 & S10+
    Last Post: 03-27-2020, 11:54 AM
  2. Ultra Bluetooth volume is trash
    By Bloodthirsty in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-26-2020, 11:37 AM
  3. Is the fps controlled by software?
    By Beth Hahn in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-26-2020, 10:34 AM
  4. Has anyone got there $200 credit yet... from samsung.com preorder
    By Borgie in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-25-2020, 07:11 PM
  5. Replies: 2
    Last Post: 03-25-2020, 12:39 PM
