Originally Posted by
mustang7757 Hi , welcome!
Power it off force off by holding power button until phone turns off then see if it goes through if not factory reset through recovery
Thank you! Holding the power button does not turn off the phone while it is stuck on the logo screen. The only thing that could turn the phone off at that point is physically removing the battery : (
Short of doing a factory reset, would somehow flashing my phone with the stock rom (if available/possible) instead perhaps resolve the issue?
Also, I've read in several places that clearing the cache is supposed to be a "safe" operation, at least on a stock rom. But, does that mostly apply to the "Recovery Mode" option to "Wipe cache partition" ? Because prior to that I used the phone's "Settings" App to clear the cache...
