1. Lean4838's Avatar
    Hi all,
    I have a Samsung Galaxy Mini running on Android Froyo 2.2. My problem is when I set an mp3 file as custom notification tone / SMS tone, the tone is played in very low sound even though my volume is all the way up.
    But when I play it using the Music app, it sounds normal and quite nice.
    Has anyone else encountered this problem? Can anyone help me?
    What I do to set my custom tone is to create a folder called "Notification" in media->audio in myfiles.
    I am not sure if this is Android specific or Hardware specific. But my aunt who owns a Galaxy 551 which also runs in Android experiences the same problem.
    Thank you!
    PS. Custom call ringtone sound fine. Only the custom SMS and notification tone becomes low
    07-03-2011 06:29 AM
  2. takeshi's Avatar
    Which volume are you adjusting? The ringer volume won't have any impact on your notifications. Ringer is for calls only. Get a sound mixer app and make sure that the notification volume is turned up.
    07-05-2011 08:24 AM
  3. Lean4838's Avatar
    Hi takeshi, thanks for replying,
    All my volume in the sound settings are full volume (even notification volume). I downloaded ringdroid and used it to set up my custom notification / SMS ring tone, but it still does not work.
    07-07-2011 06:12 AM
Tags for this Thread
