1. Kee5892's Avatar
    I searched for this on the net but didnt really find a helpful guide.
    P.S.: I dont have that switch in 'call settings'.
    04-21-2020 03:38 AM
  2. B. Diddy's Avatar
    This is not always possible -- it depends on the device. Which phone do you have?
    04-21-2020 11:09 AM
  3. Kee5892's Avatar
    Samsung A10
    04-21-2020 11:28 PM
  4. mustang7757's Avatar
    Hi, welcome!
    You can check in settings of the phone app but i think they took this feature awhile ago
    04-21-2020 11:36 PM
  5. Kee5892's Avatar
    Hi, welcome!
    I am very sure that I said "P.S.: I dont have that switch in 'call settings'."
    04-21-2020 11:47 PM
  6. blackhawkhot's Avatar
    Can't find it anywhere on Pie either.
    Probably could disable the android apk that runs it with a package disabler. No clue which one it is though.
    04-21-2020 11:52 PM
  7. mustang7757's Avatar
    Oh yeah missed that, then you definitely can't disable it .
    04-21-2020 11:53 PM
  8. blackhawkhot's Avatar
    Try Playstore there are proximity apps but not sure if any will disable it.
    With Macrodriod you can probably program macro to do it.
    Fun to play with however needs administrative privileges.
    https://play.google.com/store/apps/d...B4yWtQXYpqGIBw
    04-22-2020 12:15 AM
  1. My LG G4 is making terrible screeching noise when playing audio!
    Last Post: 04-21-2020, 07:30 PM
  2. Replies: 3
    Last Post: 04-21-2020, 11:47 AM
  3. Android TV box safe ?
    By edgie70 in forum Android TV
    Last Post: 04-21-2020, 08:40 AM
  4. Could't disable sim card 2
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 04-21-2020, 02:34 AM
