    Have a 2018 Hyundai Elantra. Can any one help. Thanks Judy
    04-26-2020 01:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean it won't automatically connect via Bluetooth, and each time you get in the car, you have to go to the phone's Bluetooth settings and tap the car entry to connect?
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    04-26-2020 06:31 PM
  3. belodion's Avatar
    1d later.
    We obviously cannot help you if you don't respond.
    04-27-2020 07:22 PM
  4. Judy127's Avatar
    Have a 2018 Hyundai Elantra and I have paired my phone to the system but it will not auto connect. So I must connect each time I get into my car. Same goes for my husband's phone. Our last phones did auto connect to this same car. Could be the model of phone that us causing the issue. Any help would be appreacted.( I did ask the question over the weekend but was not a member. I wax told to make an account which I did but did find my question any where) Phones are LGL 423DL
    belodion likes this.
    04-29-2020 08:46 PM
  5. B. Diddy's Avatar
    Thanks for registering -- I merged your post to your original one.
    Before you get in the car, is the phone already connected to another Bluetooth device, like a headset or headphones?
    04-30-2020 01:13 AM
  6. Judy127's Avatar
    No it is not connected to their devices.
    04-30-2020 06:23 AM
  7. Mooncatt's Avatar
    Is your phone set to use the car for both calls and media? I only use mine for media in my vehicle, and having the calls turned off in the phone's Bluetooth settings has caused issues with auto-connecting.
    This also may be an issue with the car radio itself.
    Laura Knotek likes this.
    04-30-2020 10:01 AM
  8. B. Diddy's Avatar
    Have you tried forgetting the connection, and then setting it up all over again?
    04-30-2020 11:28 AM
  9. Laura Knotek's Avatar
    Is there any firmware update for the car's head unit?
    mustang7757 likes this.
    04-30-2020 08:09 PM
  10. mustang7757's Avatar
    Good question , definitely could be .
    04-30-2020 08:25 PM
  11. methodman89's Avatar
    Try this ^ Forget phone from car and car from phone. Clear the cache partition and reboot.
    Rescan and pair.
    Good luck
    B. Diddy likes this.
    05-01-2020 01:23 AM
  12. Judy127's Avatar
    I will try unpairing the phone from car and car from phone. Then try to pair again. Also how would I check for firmware updare?
    05-01-2020 10:39 AM
  13. mustang7757's Avatar
    That the dealer has to check
    05-01-2020 10:53 AM
  14. B. Diddy's Avatar
    You have the factory installed stereo system, and not an aftermarket head unit, right? If it's factory installed, then contact your dealer as mustang7757 recommended. If it's aftermarket, then search for it on the web.
    05-01-2020 11:42 AM
  15. Judy127's Avatar
    I tried unpaired and repairing but still not auto correcting. I guess I will just have reconnect every time either I or my husband gest in. Thanks for all the suggestions
    05-02-2020 08:30 PM
  16. B. Diddy's Avatar
    One more question -- is the phone screen always off when you get in the car? If so, what happens if your phone screen is unlocked and you're on the homescreen when you get into the car? I'm just wondering if the phone is keeping the Bluetooth off while the screen is off, perhaps due to some power-saving mode.
    05-02-2020 09:44 PM
  1. Ambient display not always working
    By patruns in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 05-02-2020, 12:40 PM
  2. my Airtel 4g sim is not working .
    Last Post: 04-26-2020, 06:30 PM
  3. Moving to a new phone (after a bad first attempt)
    By Android Central Question in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 04-26-2020, 02:42 PM
  4. [Free] [App] Tasbeeh Asistant – Zikr, Tasbih, and Duas
    By App Addict in forum Android Apps
    Last Post: 04-26-2020, 12:50 PM
