1. hell911's Avatar
    today, i acivated the lock screen password, restarted the phone, now it wont turn ON. there is no logo screen, and no vibration.
    i tried removing and plugging again the battery, still no luck
    removed battery, connected usb cable, press power button, no luck.
    should i call at&t? what do they ask for when i need to replace the phone?
    pls help.
    09-07-2013 01:40 PM
  2. hell911's Avatar
    checked the battery, inserted it into my friend's phone, battery is fine.
    cable is also fine.
    i didnt root/rom.. use any kind of custom installation.
    pls help.
    it wont vibrate, no sound, no login screen.
    09-07-2013 06:19 PM
  3. bewpy's Avatar
    I personally have no idea.. I would try doing a hard reset if at all possible, if not then I would definitely call ATT .. They will probably ask for security info for the account to make sure its actually your account.. and idk about ATT, but I know with tmobile they send you a new phone, then you just return the old one in the same box.
    09-07-2013 07:05 PM
  4. hell911's Avatar
    hard reset has something to do with volume button right? i did that already.
    what security info do they ask, do the ask for like receipt or acct number, or something?
    09-07-2013 07:42 PM
  1. LG G Pad 8.3 Hands-On
    By srkmagnus in forum LG G Pad 8.3
    Last Post: 12-11-2013, 02:13 PM
  2. HELP - Stuck in LG Boot Loop after upgrade.
    By shishirs in forum LG Optimus G
    Last Post: 09-26-2013, 12:12 PM
  3. Please help me to sort out some contacts issues.
    By scrumpypaul in forum General Help and How To
    Last Post: 09-13-2013, 01:39 PM
  4. Nova Launcher on Note
    By Super Turtleman in forum Verizon Galaxy Note 2
    Last Post: 09-11-2013, 07:36 AM
  5. Replies: 3
    Last Post: 09-09-2013, 07:36 PM
