1. Mr.Mcgoo's Avatar
    Hi,
    Figured this was general so I would post it here, I went back to school where I am taking some classes online and need to type some papers while on the go to at work so I need access to word mostly but the suite would be best. So I have a full size laptop that I usually utilize at home for this and have a nexus 7 and iPad-2 for on the go but the iPad does not fit for this. So my question after all that is I was trying to figure out if the surface 2 would be worth picking up or a small laptop in the same price range, or is there a better option using android that I can do this with that I'm missing?
    Thanks
    10-17-2013 08:56 AM
  2. Golfdriver97's Avatar
    Hi,
    Thanks
    I would suggest a laptop. You already seem to have the tablets covered anyway.
    10-17-2013 09:03 AM
  3. Algus's Avatar
    There are several good office suites for Android and you can connect a Bluetooth keyboard to your tab (many even come with stands!) to do word processing. This might be cheaper than buying another device. I personally think the N7 is a bit small for prolonged office work, which is why I have a chromebook as well, but your mileage may vary.
    Sent from my Nexus 7 using Tapatalk 4
    10-17-2013 10:38 AM
  4. Mr.Mcgoo's Avatar
    Thanks, the iPad 2 for me is just a couch web surfer and answer emails other than that I do not really do much with it was just going to sell it. So you are using a chromebook and what are you using for word documents and do you find any issues with converting back and fourth?
    10-17-2013 12:31 PM
  5. Algus's Avatar
    Well with the chromebook, Google Drive is the only real solution for office stuff. There are some other suites but none are as user friendly. Good thing about that is since I'm using Google Docs, I can work on my chromebook, save to my drive, and pull it up on my N7. MS Word is the standard and most other words processors can open and save in that format. On my Android, I prefer Office Pro 7 which can also save to doc and docx.
    10-17-2013 10:03 PM
  1. Can you help me UNROOT my Tab 3?
    By silverbastet in forum Samsung Galaxy Tab 3
    Last Post: 01-03-2016, 02:44 PM
  2. Galaxy s3 won't turn on. Help!
    By cjulia in forum AT&T Galaxy S III
    Last Post: 11-27-2013, 10:28 AM
  3. need help new here
    By dscannapieco in forum Verizon Galaxy Note 2
    Last Post: 10-18-2013, 08:18 AM
  4. Still looking for the right small tablet
    By besb421 in forum General News & Discussion
    Last Post: 10-17-2013, 05:58 AM
  5. Newbie looking for help with contacts...
    By MichaelTaylor91 in forum Samsung Galaxy S4
    Last Post: 10-16-2013, 04:04 PM
