1. Arms84's Avatar
    I bought a Droid Maxx and like it enough but came across battery cases that I did not know about, like the one Incipio offers @ Samsung Galaxy S4 Battery Case | Incipio offGRID GS4 | Incipio. Would an S4 with this attached be better than an Droid Maxx, due to the screen and other performance specs. I had an S3 but it frooze on me often within first week and once took 30 mins to restart. Kinda skeptical about Samsung quality.
    10-21-2013 05:47 PM
  2. srkmagnus's Avatar
    Sorry to hear about your bad experience with the S3.
    It really depends on how you use the device. The Maxx is a good device and battery life shouldn't be an issue unless you use the device often and intensely. On the flip-side, the S4 is also a good device but stock battery life is probably not the same as the Maxx. It's really going to come down to the device you like the most since their is a battery solution to get you added battery life. Ask yourself which one you like and will likely enjoy and go with that one. Honestly, you can't go wrong with either device.
    10-28-2013 02:32 AM
  1. Sudden battery drain below 40%
    By TekNinja81 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 12-09-2013, 05:19 AM
  2. G2 Wireless Charging Case?
    By Malkavian99 in forum LG G2
    Last Post: 11-23-2013, 05:36 PM
  3. Samsung Galaxy S3 - Time for a new battery?
    By Firefly_mnc in forum Samsung Galaxy S3
    Last Post: 10-22-2013, 02:21 AM
  4. google services battery drain fix!!!
    By maricopa1963 in forum Samsung Galaxy S4
    Last Post: 10-21-2013, 07:57 PM
  5. waterproof case for taking pictures underwater?
    By J HighNote in forum Samsung Galaxy Note 3
    Last Post: 10-21-2013, 06:29 PM
