1. ShAdoWSKy's Avatar
    If you guys had to choose one, would you invest into a Qi wireless charger? or an external-portable battery pack?
    09-07-2014 10:25 PM
  2. FRoStYisGoD's Avatar
    That really depends on who you are and what you want. I prefer the wireless charging
    Sent from my Nexus 5
    09-07-2014 11:10 PM
  3. B. Diddy's Avatar
    It also depends on your usage pattern. Are you using it a lot when away from home? If so, then an external battery pack makes more sense.
    09-07-2014 11:15 PM
  4. zorak950's Avatar
    They're made for different things. It's not really an either/or situation.
    09-07-2014 11:37 PM
  5. ShAdoWSKy's Avatar
    Does wireless charging have any negative effects on the battery? Also I've read that wireless charging is slower than wired charging and also overheats your phone more easily.
    09-08-2014 03:46 AM
  6. FRoStYisGoD's Avatar
    I haven't noticed any negative effects, only positive for me. I don't find that it charges the phone that much slower, and if it does then its not a huge big deal to me. I also don't find my phone being any more overly hot then normal or when using the chord, but that's of course just my opinion.
    09-08-2014 04:58 PM
  1. Replies: 158
    Last Post: 09-29-2014, 12:36 PM
  2. Nova causing Battery Drain?
    By SpookDroid in forum Samsung Galaxy Tab S 10.5
    Last Post: 09-07-2014, 10:10 PM
  3. Vodafone S5 phones get a update or do they ??
    By Northern.dj in forum Samsung Galaxy S5
    Last Post: 09-07-2014, 09:01 PM
  4. Slimport or MHL?
    By npaladin-2000 in forum Sony Xperia Z3
    Last Post: 09-07-2014, 08:54 PM
  5. Galaxy Nexus Battery Problems
    By ASHLEY JOSEPH in forum Ask a Question
    Last Post: 09-07-2014, 07:07 PM
