Hi all,
have been lurking around here basically every time I research stuff for my android devices, but I'm a first time poster.
So first of all: thanks all for your advice and opinions so far
This time I am out to find out what the touch issues with Android really are about.
A video by gigaom [1] shows quite well what I mean.
I quickly hit upon the Touchmarks blog posts by Agawi, wich sadly are down (at the moment?) but luckily were archived and can be found in the WayBack Machine [2].
On every Android device I have tried (I own an Galaxy Nexus and a Nexus 7, but I went down to MediaMarkt the other day to try others) this lag kills the experience for everything latency-critical.
Wherever I was able to use the Developer options, I enabled the "Show touches" option and could reliably see the registered touches lagging behind my finger. So it is most probably not an issue of the active app, since this even happens in the launcher.
This is why I would always recommend an iPad for note-taking, e.g. in academia, and would even (I cannot believe I am typing this) consider one myself for the next tablet. When writing free-hand, the experience of seeing the "ink" lag behind the pen is somewhat similar to hearing the own voice with a 200ms delay: it lets you stutter, hesitate, and is generally really, really, REALLY unpleasing.
Given how fundamentally this problem of the Android system affects all other parts of the experience, there must be/have been serious efforts to address it.
So, my question to all of you is if there are coordinated efforts to adress touch lag issues in Android, where these efforts are documented and what the progress so far (if any) has been. The Agawi repository seems to be partly available at github [3]
Or is this a hardware issue and I have simply not found the right devices to test?
Thanks all for your time, and sorry for the long post...
LINKS
Please forgive the uglyness here, but real links are a thing for people with >=10 posts.
So please, use these very specific google queries. Or edit my post if you can.
[1] google for "Video: Android touch lag (and a possible solution)"
[2] Google "TouchMarks I: Smartphone Touchscreen Latencies" and use the cached version. Enter the URL into the WayBack Machine if you want it prettier!
[3] google for "Source for the TouchMarks benchmarks"
LINKS
