1. Leonodas's Avatar
    The back was coming off already, so I guess that's my fault for not securing it, although the little clips wouldn't all go in and click into the back -- so, a defective back. Besides the point.
    The battery has a warning on it which states not to remove it and that the battery is non-removable. I have made no attempt to remove the battery.
    I drop it and the battery came loose. Naturally, the phone shut off, but then would not turn on again. I went to go charge it, and it the little "M" logo shows up, then shows me a charging battery of 0%, which quickly goes to 5%. The screen will then close down (energy saving I guess) after a few seconds and when I hit the power button to turn it on again, its "fully charged."
    If I take it off the charger, the screen goes dark and it will not even attempt to turn on. I have tried to turn it on while charging, but when I hold the power button, it simply blacks out; basically, it shuts off. Force reboot (holding volume down in tandem) produces the same useless result.
    I am going to try and leave it to charge for an hour, but I'm running out of solutions. This could not come at a worse possible time for me, but I that's of no concern here anyway. Please post whatever solutions you can.
    10-01-2014 09:42 AM
  2. Golfdriver97's Avatar
    If it is non removable, it was probably hard wired into the phone. It may be possible the fall pulled the connections loose. As for how to fix it, I am not sure. You can try searching your device on YouTube. iFixit, if they have your device, does wonderful tear-down videos.
    10-01-2014 09:54 AM
  1. Kairos Smartwatch wil not support Android Wear
    By aitt in forum Android Wear / Wear OS
    Last Post: 10-05-2014, 11:53 PM
  2. Can anyone help me out with some network issues I am having?
    By runnergirl34551 in forum HTC One M7
    Last Post: 10-02-2014, 08:45 AM
  3. how do i get ads like this off my galaxy s5
    By ryan mcgovern in forum Ask a Question
    Last Post: 10-01-2014, 07:06 PM
  4. My HTC Inspiration will not power on. What do I do?
    Last Post: 10-01-2014, 09:43 AM
  5. Can you help me with SIM network settings?
    Last Post: 10-01-2014, 09:40 AM
