1. rockitdog23's Avatar
    I have a VZW S6 that is unlocked. I'd like to join either Cricket or Metro PCS (preferably Metro) but am wondering which device will give me the best experience based on network compatibility. Thanks!
    Looking to take advantage of Metro PCS and their unlimited data for $60/mo!
    04-30-2015 01:06 PM
  2. 32gig's Avatar
    Just an FYI, cricket throttles your download speed to 8mbps.. metro does not.. that 8 Mbps is max, not typical speeds.. have read reviews stating most get between 2-6 Mbps download speeds.. I use straight talk and get upwards of 24mbps.. just something to think about..
    Also, cricket runs on at&ts network, and metro runs on T-Mobile..
    04-30-2015 01:45 PM
  3. Rukbat's Avatar
    You choose by which carrier - AT&T or TMobile - gives you the best coverage where you need coverage. Fantastic service on the best phone where there's no signal isn't worth 2 cents. There are apps that will show you the various towers around you and what signal strength you're getting from each. (Check the actual places you need signal - at your desk, not on the street in front of the building. Dead spots can be as small as inches in diameter.)
    04-30-2015 03:54 PM
  4. Almeuit's Avatar
    Best experience will differ greatly depending where you live. We can't answer since it may be great for us .. but horrible for your area.
    04-30-2015 04:37 PM
  1. How do I turn on the grayscale effect on my Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 06-17-2016, 04:29 PM
  2. Replies: 5
    Last Post: 05-01-2015, 10:28 AM
  3. How do I play uploaded songs only on my Google Play music?
    By AC Question in forum Google Play Store
    Last Post: 04-30-2015, 07:41 PM
  4. How do I extend the timeout on the Note 4's s screen?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-30-2015, 04:39 PM
  5. Why won't my Samsung S3 Mini turn on?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 04-30-2015, 01:27 PM
