1. andremtngro379's Avatar
    Need best apps to sabe baterry, can u help me?
    Enviado do meu Smart A65 através de Tapatalk
    07-16-2015 11:56 AM
  2. Crashdamage's Avatar
    So-called Battery Saver Apps are a waste of time. Not only are they ineffective, some actually use more power than they save.
    Just be careful setting up the phone. Use common sense. Don't set email to sync every 2 minutes. Turn the screen brightness down some, stuff like that.
    Android since v1.0. Linux user since 2001.
    07-16-2015 12:07 PM
  3. Neo_ii_Droid's Avatar
    Hello and welcome to Android Central!
    Like what Crashdamage stated above. Here's a thread for some tips on saving your battery: http://forums.androidcentral.com/amb...ving-tips.html
    Also see this thread: http://forums.androidcentral.com/gen...ml#post4556664
    Hope you find what you're looking for and enjoy!
    07-16-2015 01:50 PM
  4. sting7k's Avatar
    07-16-2015 02:25 PM
  5. D13H4RD2L1V3's Avatar
    An app won't give you 50% more battery life out of your battery. The only thing that can is an actual battery that's bigger in capacity.
    Just follow the tips Neo_ii_Droid linked above and you should be fine. Also read the thread that he linked (I made that), since it explains why many of us do not recommend installing apps like Battery Doctor, Du Battery Saver and whatnot.
    07-17-2015 04:04 AM
  1. Yet another battery drain thread
    By lazor12 in forum HTC One M8
    Last Post: 09-13-2015, 04:03 PM
  2. Battery lost 60% in 2 hours
    By AlexMarie15 in forum Samsung Galaxy Note 4
    Last Post: 07-23-2015, 04:02 PM
  3. Battery life worse after reboot.
    By tonyr6 in forum Android 5.0 Lollipop
    Last Post: 07-18-2015, 03:17 PM
  4. Replies: 1
    Last Post: 07-16-2015, 10:24 AM
  5. Why can't I turn my phone on, despite replacing the battery?
    Last Post: 07-15-2015, 10:24 PM
