1. meltedice's Avatar
    I got my S6 edge for a month now, I still the configuration and customization of my Nexus 5 and z10
    recently the battery life of my phone getting pretty bad, only can last me for less than 10 hours for a mix of heavy and moderate use.
    this is the snapshot from GSam Battery app after I woke up in the morning (was using my sleep app to track the sleep). The kernel and android system used a lot of the battery, is that normal? And also i can see my wifi is using somehow a half of my battery, should I change any setting to lower the battery consumption?
    07-23-2015 06:29 PM
  2. Duduz's Avatar
    i also have been experiencing the same problem,
    it goes well unless i use my mobile data option it kills the battery thoroughly
    07-23-2015 08:39 PM
  1. Replies: 1
    Last Post: 07-25-2015, 09:42 PM
  2. Replies: 3
    Last Post: 07-23-2015, 08:14 PM
  3. Replies: 0
    Last Post: 07-23-2015, 06:04 PM
  4. How to clean the edges?
    By Erika Contreras in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 07-23-2015, 05:33 PM
  5. How do I get rid of message+?
    Last Post: 07-23-2015, 04:59 PM
