Originally Posted by
trsbbs It is almost impossible to find a good screen protector and forget tempered glass protectors for the Edge.
It's near impossible on the S7 as well... the screen profile isn't flat. There is a subtle bulge in the glass and the center is a fair amount farther out than the margins. When my wife had a S7, I gave up trying to get a protector that fit, nevermind a glass one. The plastic ones that DID fit properly were paper thin sheets and were a nightmare to fit. I stopped trying.
If you are a light user and don't mind a smaller screen, the S7 is a good choice. The battery is a lot smaller than the Edge, so you would find yourself charging far more often.
