1. Tom Westrick's Avatar
    Jerry,
    I am looking for a new portable battery that would be powerful enough to charge both my phone and my laptop. Right now, my laptop is an Asus Chromebook C302 and it requires 45W to charge, but I'd like something that can charge in the 90-100W range in case I get larger laptops in the future. My full desired specs are:
    2 USB-C ports that can output 100W of power. One/both of them would also be used to charge the portable battery itself. Support for USB-PD, if that's not already a given.
    1 USB-A port, I'm not too concerned on the speeds for this since it will be used
    27,000 mah battery, since that is the legal limit for taking a battery onto a plane
    A plain black metal case
    An LED battery life indicator.
    I've seen instruction guides on building a portable battery, but they use older controllers with USB-A and micro-USB ports. I know this will require a longer answer than a forum post may be able to give, but anything you can do to point me in the right direction would be appreciated.
    01-26-2017 08:13 AM
  2. Jerry Hildenbrand's Avatar
    I'm going to try and discourage you from doing this. We're so used to low power low current batteries that we forget what kind of damage any chemical cell(s) can do once you're dealing with those kinds of power factors.
    Having said that, point me at the instructions for one with legacy USB options that makes sense to you and I'll take a look. Basically, the storage side will be the same — cells are cells and all they do is store power. The regulators, input and output circuits and overcurrent protection would probably all need to be different.
    And remember — building something like this could actually kill you. I(A) = P(W) / V(V) means you'll be dealing with (potentially) 20 amps. 200 milliamps can kill you if you really try, but 20 amps makes it easy.
    01-26-2017 12:34 PM
  3. Tom Westrick's Avatar
    If possible, I'd like to just buy something like this and change the output port from a DC output to a USB-C output https://www.amazon.com/gp/product/B0...cUvbUpU5657970
    01-26-2017 05:32 PM
  1. Switching to T-mobile
    By Keesey_t in forum Motorola Droid Ultra
    Last Post: 11-30-2017, 09:21 AM
  2. How do we change the Battery icon in 7.x?
    By cgardnervt in forum OnePlus 3 & 3T
    Last Post: 02-01-2017, 04:58 AM
  3. Do you see Android apps coming to chromeboxes?
    By rinkeedink in forum Ask a Question
    Last Post: 01-30-2017, 10:35 AM
  4. Replies: 1
    Last Post: 01-26-2017, 08:56 AM
  5. Note 3 power cut when still have battery
    By quakquakquak in forum Ask a Question
    Last Post: 01-26-2017, 07:46 AM
