1. Lexamundo's Avatar
    I use a phone case battery pack (PoweBear) and am starting to wonder if the antenna area of the phone was considered or ingored in the engineering and construction of battery cases for various phone models. I'm betting antenna location is ignored. The actual signal strength reading (not bars) of my Samsung S6 is slightly lower by a few db with the case vs. without.
    Anyone have solid info to share?
    Matty likes this.
    02-20-2017 03:46 PM
  2. Tim1954's Avatar
    The main antenna on the S6 is down the bottom of that device at the back. It's a loop around an inch high roughly. If you cover that with anything that blocks radio signal, your device has to push more power to transmit and it will be a bit more "deaf". I'm not sure if the components of the battery are radio opaque or not...
    02-20-2017 06:22 PM
  3. Tsepz_GP's Avatar
    I think it depends on the case.
    Most cases are made of Polycarbonate, which is a very strong plastic that phones used to be made of before the Glass and Metal fad began.
    Polycarbonate allows signal to go through with ease so I would assume MOST cases do not affect signal,or at least not to a significant degree,in actual fact I believe they can improve it as they create a buffer between you and the phone's antennas, which without a case you want would possibly block, especially in metal phone's.
    02-20-2017 11:23 PM
  4. Matty's Avatar
    Any object that you place between your phone and the cell tower, will hurt the signal a little. I think if you purchases cases that are from reputable manufacturers, they normally do pay some attention to signal strength. It's mostly focussed around the actual battery design though. As long as the battery case isn't made out of any metal you should be fine. The phone may use a little more power to send and receive signal but i wouldn't worry to much about it.
    02-21-2017 08:45 AM
  5. sarahgad's Avatar
    May be one of the reasons i like to use my S7 without any sort of cases.
    02-23-2017 02:05 AM
  1. How can I factory Reset my Phone?
    Last Post: 02-20-2017, 06:00 PM
  2. can a sprint phone be used on virgin moble
    Last Post: 02-20-2017, 05:42 PM
  3. Replies: 1
    Last Post: 02-20-2017, 03:41 PM
  4. How can my boyfriend see all my calls on his phone
    Last Post: 02-20-2017, 03:37 PM
