If your web browser user agent is one that doesn't run on cellphones, you're tethering to another device. If you're running a program that doesn't exist for cellphones, you're tethering. There are many ways of telling that you're tethering. (A web browser even tells the site what operating system it's running on. How else do you think that, if you go to, say, Firefox, you go to the Windows download page, or the Linux download page or whatever you're running? [I don't use computers with fruit, but I'd imagine it's the same thing for Macs, iDevices, etc.])
Some carriers in the US allow you so much tethering that you'd never use it all, some allow almost none even with an unlimited plan. But choose your carrier by coverage. Having unlimited data and unlimited tethering - and no signal - does you no good. And there's no one carrier that's best all over, despite what you'll see in the TV ads. Verizon, which probably has the best coverage overall, does have some pretty bad dead spots. Sprint, which probably has the worst coverage, is great if you're getting -90dbm from them where you'll be. (And if you need a lot of data, it's going to cost - if it's not AT&T, Sprint, TMobile, US Cellular and Verizon, it's not a carrier, it's an MVNO, a mobile virtual network operator, that buys bandwidth from one of the 5 and sells you a small piece of it. They may be cheaper, but they're the first customers to get throttled when usage goes up [like at midterms in a college town], and they usually throttle at a much smaller amount of data.)
06-27-2019 05:27 PM
